So I'm trying to resurrect a 1980 4wd pickup, I'm a full on 1 banana mechanic, but trying to learn
old trannys was pretty unhealthy
I have a 84 4wd parts truck, pulled the 5g3 and t-case out of it.
Bolting up the g52, bolt pattern was the same, but had to get a bunch of odd bolts to make it fit, (some boith sides were unthreaded etc), I _THINK_ I have that part figured out.
My understanding is that the g52 is 4.15" longer
I have the trans cross members and drive shafts from both trucks.
Will either cross member bolt right up, or will i need to cut an weld and bodge/jerry rig something together?
I remember reading about an aftermarket dual/single t-case cross member that works, and leaves you open to swap later, but i can't find it, does anyone remember what it was?
(t-case out of 80 is still good, so might case swap it and throw it on someday)
My current plan on the drive shafts is to use the 84 driveshafts, and swap the 80 u-joint ends to fit the 3rd members, is there a better way?
One unrelated question, there is a swap to a double brake master from a later truck that's really easy, but again, i can't find the
info again. Does anyone remember what master that is?
Thanks everyone!
Cal
Thanks everyone!
Cal
