- Location
- United States
Hello Everyone-
I am selling my FJ40 I have owned since 2007.
Here is a long list of things that have been done to the vehicle. Please email or pm with any further questions.
The truck is in great running condition. Reason for sale is an added family member as well as wife wanting something else!!
In addition to the list below I have had the roof repainted. When I purchased the vehicle the previous owner scrapped the top along his garage door.
The truck is ready to enjoy.
Stripped down to bare frame, sand blasted & refinished semi-gloss black
CHEVY SMALL BLOCK 350 (BRAND NEW CRATE MOTOR)
New Dist
New starter
New alt.
New water pump
New pulleys.
New manifold
New block hugger headers.
New wires.
New cap and rotor.
New Battery cables.
New Optima battery.
Rebuilt 350 turbohydromatic Trans
Rebuilt front and rear drive lines.
Overhauled Toyota transfer case replaced all seals & bearings.
Overhauled front end & rear axel. replaced all seals bearings.
All components were cleaned and repainted.
New complete custom exhaust system
Advanced Adapters engine and trans mounts.
Replaced all lines & hoses
Heater cores flushed & pressure tested
Front and rear heater units repaired & refinished working perfectly
Brakes Refurbished the factory power brake system
New master cylinder
New wheel cylinders and calipers.
Cleaned and refinished all valves, lines & booster Front disc Brakes & rear drums rebuilt.
Whole system checked & rechecked
Steering & Suspension
Added GM Saginaw power steering system
Tie rods replaced All front end components replaced or checked, cleaned & refinished
New steering dampener
Steering correction kit added creating a small lift apx 2 inches
Professional front end alignment
Reupholstered front bucket seats & rear jump seats
All seat frames sand blasted & refinished.
All seats professionally re upholstered factory color.
Roll bar sand blasted & re finished with factory pads
New headliner
New OEM dash pad
Floor coated in sound deadening & chip resistant material that is color matched.
New OEM sun visors
All gauges, warning lamps & controls working perfectly
Wiring harness disassembled tested, repaired as needed & rewrapped
New seat belts.
Body & Exterior Removed from frame & disassembled
Metal dipped to remove rust & paint
No panels were replaced, all original floors and tub.
Door skins separated from shells rust removed, re welded & rust proofed
Grille bib dissected, sand blasted, re welded & rust proofed
Cowl broken down, s/b, re welded, r/pd' All components of removable top broken down, s/b, welded, r/pd'
Tub broken down as necessary s/b, weld, r/pd'
Top rain gutter removed from roof and treated
New OEM fenders
All nuts & bolts have been coated, many are new Toyota.
All weather stripping replaced with new OEM
All body bushings replaced
New rear bumperetts
Brand new OEM emblems & badges
Undercoating applied while a bare tub
All new OEM lamps (turn signals, tail lamps ect.)
All paint work done with quality PPG products in a heated down draft booth Colors are based on factory Toyota paint codes (freeborn red)
New OEM wheels powder coated to original colors
New OEM hub caps 5 new 33x9.5x15 Super Swamper TSL's Options
Old Man Emu suspension
Braided brake lines
Tuffy center console
Insulation - FJ40 Front Floor - Foil Backed - Pre-Cut
Mats - FJ40 - Aussie PVC 3 PCE Set - Black -
New Dist
New starter
New alt.
New water pump
New pulleys.
New manifold
New wires.
New cap and rotor.
New Battery cables.
New Optima battery.
New master cylinder
New headliner
New OEM dash pad
New OEM sun visors
New seat belts.
New OEM fenders
New rear bumperetts
Braided brake lines
