big thank you Steam; don't know differences between the series though, will have to do some research; still trying to figure this one out think the V means Van = commercial vehicle designation for Japanese market; but fj55 LG ???Would either of these help? There's no years marked on them & I don't have knowledge of the model lettering.
I could try to take better/larger pictures of'em.
P_H another thank you for so much help and advice over the years; cleaned up the fuses, holders and connectors in fuse box and now headlights work ; the headlight issue was what started this dilemma ; will get under the pig and get to the starter and its wiring to check voltage in and like your guidance on grounding negative side of coil ;You can Turn the engine using a wrench on the alternator nut and pulling the belt tight.
You don’t need to have the points closed if you just ground the - side of the coil.
The crossing lines on the schematic that you circled are probably not connected because if they were they would habe different color codes, which would mean that they are different circuits.
The “exciter” wire that bypasses the ballast resistor starts at the starter solenoid as a pig tailed connector and goes to the + side of the coil. It is a smaller diameter black wire with yellow stripe.
Remember that the ignition circuit is not fused, so it is not a headlight problem.
If your headlights don’t work, this could be related because all circuits get power from the battery through the amp meter. Does any circuit have power? If not check connections at the amp meter and at the fusible link (if you have one). You can’t tell it is good by looking at it. Measure the voltage with the circuit on and powered.
Uhhh, yeeeaaaahhh...this is why she wouldn't crank maybe can go deeper into the "runs only in start" issue
P_H; big thank you again; I appreciate your input and guidance tremendously and don't consider it harping just steering adjustments its a process of elimination and don't have a very reliable wiring diagram also don't have the usual fusible link; it does have a fusible link but it goes to the electric power steeringIt is hard to know what is going on with the fuse block by just looking at the picture. There is some corrosion where it doesn’t matter. Where it matters is on the connectors for the plugs and fuses.
I hate to keep harping on it, but the fuse block is not the problem for your ignition because the ignition is not fused. The power comes from the battery fusible link to the amp meter and from there to the ignition switch and then the fuse block.
replaced the old switch with a lovely NOS from ToyotaMatt as recommended but is doing the same as the old one; runs in start or hotwired will get to it again in the morningPicture linky no worky.
P_H redid the pix; hope they worky now
The black wire at the distributor is probably the wire between the points and the - side of the coil. yep; it is solid black; will test for continuity tomorrow and no mention of color on the wiring diagram or of a red/black wire coming off negative side of coil. BUT it is transition model with the 1 1/2 F engine
If you have 12V at the ballast resistor and 9V at the + side of the coil with the ignition on and the - side of the coil grounded, then that is normal and the engine should run. If you push start it , it should run fine. I’m thinking it has to be an oddball problem with the switch itself that either grounds the ignition wire when you let off of the start switch or it interrupts the power to the coil. I would bite the bullet and replace the switch and hope for the best.
Travis; good observation; pretty much think have ruled out a bad resistor as when tested it is doing its job reducing the voltage from 12 to 9; there is a gremlin hiding somewhereSorry if you have already figured this out. My 76 had the same problem turned out to be a bad coil resistor. I bypassed it and it ran fine. Replaced it and that fixed the problem.
Steamer; just did your suggestion and hot wired her from the switch she starts and runs sweetly but dies as soon as take off clip there is something very screwy lurking here underneathA jumper like this would bypass what’s in between them and also test what’s on either end.
You could probably get an alligator clip on that switch terminal.
