Our original 1974 FJ 55 was having headlight issues and was trouble shooting the fuses underneath the panel; after trouble shooting the fuses that all looked good started the pig up again but would only run in start; ; OK fusible link looks good and it runs if hot wired battery to + on coil or both sides ballast resistor has to be the ignition switch !; got a lovely original NOS ignition switch from ToyotaMatt............. Matt; a BIG thank you for all the help getting the switch to me at short notice ; installed it BUT but same issue; runs on start; runs if i hotwire battery to coil or battery to either side of ballast resistor and the fusible link "fuse" looks good; somewhere the current is cutting off when ignition switch turns to run any advice?: am scared to drive her out of where she sits with the battery hotwired to ballast resistor or coil; appreciate any advice on where to go next;
Lou
Lou
