I've spent a considerable amount of time searching and learning about my FJ40 suspension and thought I'd share my current setup as it might be helpful to others on the forum. I would also like to hear from the experts to confirm pinion and caster angle setup.
Specs
- 1972 FJ40
- Spring Under Axle
- OME Dakar Leaf Springs - CS002F & CS002R (Medium/Heavy Duty 2" - 2 1/2" Lift)
- OME Poly Spring Bushings - OMESB30
- OME Steering Stabilizer
- Front Shocks: Bilstein F4-BE5-6251-H5
- Rear Shocks: Bilstein F4-BE5-6252-H5
- Cool Cruisers Greaseable Tri Shackle Kit (3 1/8" length pin to pin)
- Cool Cruisers Greaseable Spring Hanger Pins (15 mm pins)
- 4 Plus Products U-Bolt Flip Kits Front & Rear
- BF Goodrich KM2 Tires (31 x 10.50 R 15)
Weight Considerations
- 4 Plus Products Bull Bar Front Bumper (no winch yet)
- 4 Plus Products Rear Full Tire & Cooler Carrier
- Metal Tech Full Profile Roll Cage
Replaced original suspension last fall which increased the front ride height by 1" and the rear by 2 3/4". No more saggy leafs and the stance was perfectly level. Ride quality is great in comparison to the 46 year old original equipment.
So, after driving and wheeling the rig since last fall and to give things time to settle I thought I'd better check the pinion angles front and rear. Additional reading and researching was required as I know nothing about pinion settings and I'm still learning...
At this point I could use some confirmation and direction from the experts.
Current Rear Settings
Trans Output: 2.0* Down (Engine is also 2.0* Down as measured from valve cover)
Drive Shaft: 9.0* Down
Axle Pinion: 7.0* Up
Based on these measurements and from what I've learned it looks like I'm going to need 5.0* Shims in the rear to bring the pinion down to 2* Up? As strongly suggested on the forum I will be purchasing Steel Shims.
Current Front Settings
Trans Output: 2.0* Up
Drive Shaft: 11.0* Down
Axle Pinion: 1.0* Up
The front is a bit more complicated given caster.
From what I've read, stock caster is positive 1*-3* or 2*
Could use some help here to determine correct setup.
Happy to add pictures if it would be helpful.
Thanks!
Specs
- 1972 FJ40
- Spring Under Axle
Thanks!
