- Thread starter
- #41
Yep, it is a sheet metal brake that can fold shallow boxes and pans. Been wanting one for a long time and this one ticked almost all the boxes. Was too good a price to turn down.
It actually has half a lift gate, the hydraulics and lift arm are all present and working, just needs the parallel arms and a folding platform. Apparently the original seized up on the previous owner so he cut it off. I would love to find a replacement, but barring that I plan to eventually build a basic platform for it.A lift gate would be nice to have on this truck. Great deal on the batteries and charger.
You sonova bitch, gotta stop sending me Craigslist ads lol gunna get my wife to divorce me soon.....
Refer truck - heavy equipment - by owner - sale - craigslist
1985 International Diesel refer 16ft. van with hydraulic lift gate. 2 cylinder diesel powered refer manual transmission with 2sp. rear axle. Tires are great with disc brakes on all four 140,000...kalispell.craigslist.org
Ha! In all seriousness, I wouldn’t recommend it. Really it just ends up being another needy, old vehicle to take care of. I had an unusual set of circumstances that made it make slightly more sense than normal. Not an easy thing to work out of, especially when I’m working on one of my cars, but it’s better than nothing for tool storage.You sonova bitch, gotta stop sending me Craigslist ads lol gunna get my wife to divorce me soon.....
The listing made a good point, cheaper than a shed....I like that argument, will see if it works
Nice work your rolling shop. I've got to go back to the beginning of this thread and refresh my memory....didn't you drive that thing home from like really far away lol?
Hopefully you installed new hub seals as well. They were obviously leaking.Finally got around to pulling apart the RH front brake, was pleasantly surprised to find the wheel cylinders in really good shape. Looks like they were replaced sometime in the not too distant past (at least relative to how old the truck is). I decided to just repack the wheel bearings and put it back together.
An oil change was also in order. My drain pan very nearly overflowed, but was just able to keep up.
This truck appears to have the larger oil sump and big filter, it took just shy of 9 quarts to refill.
After the oil change I put fresh fluid in the brake master cylinder and slowly pumped the pedal for about 5 minutes. Both the master cylinder and booster cylinder seem to have self bled doing that, I was able to get a decent pedal feel and reasonable stopping power back. Still need to bleed each wheel, but for now I can move the truck around the yard without fear of crashing into something.
Unfortunately not, I didn't have them on hand and needed to get the truck back on its wheels by evening. The seal wasn't leaking too bad, I had just sprayed the inside of the drum and the pads down with brake cleaner before I took the photos, so it looks wetter than it was. Fortunately the truck won't see more than a hundred miles or so per year, so I'll just keep an eye on them.Hopefully you installed new hub seals as well. They were obviously leaking.
Generally on these type of things i go ahead and replace everything rubber that contacts brake fluid.Brake day. I've dealt with quite a few drum brake systems but never one this big. Everything was quite heavy and extremely dirty from all the leaking brake fluid. Getting it all torn down wasn't too difficult though, apart from dealing with the brake shoe springs.
I had planned on only rebuilding one cylinder but had purchased two rebuild kits just in case; once I got the drum off it became obvious that while only one cylinder had leaked, the other wasn't far off. Fortunately both cylinders were ok apart from a bit of crud built up inside, a quick hone cleaned them up nicely. New cylinders are NLA for this truck, so I was very happy to see the bores shine up nicely on both of them. The shoes and drum were both soaking with brake fluid, it took two cans of brake cleaner to clean them up. Overall, apart from the fluid everywhere things looked pretty good. Lots of pad left, the drum was in good shape, and the wheel bearings looked really nice still.
Another fight with the brake shoe springs to get everything back together. I'm not sure if this was necessary but I put a dab of grease on each end of each brake shoe where it rests on the cylinders. I also thoroughly re-greased the wheel bearings before putting the drum and hub back on just to be on the safe side.
Back on its wheels! I haven't bled the brakes yet; thinking I should probably have a look at the brakes on the other side, they can't be too much different and might as well get them rebuilt now so I don't have to bleed the system twice.
