Does anyone know if there are any issues involved with putting T100 wheels on an 80? Thanks!
e9999 said:Jenny, I have a set of Tundra/Sequoia/T100 (?) steelies on mine (probably early 2000s). These are 16x7. Backspacing is just right. The center hole fits better than the OEM LC alloys. Some will say that they are too narrow for the usual 285s etc tires, and they are indeed maybe a tad narrower than the typical app guide for 285s, but most will OTOH say that they will retain better aired down tires, and should exhibit no problem altogether. That is my impression as well. My measurements show that my 285s are maybe 1/2" or 1/4" narrower sidewall to sw with the 16x7 which I don't see as a problem.
All in all, a great inexpensive way to get a second set if you like the styling. Very cheap to find in sets of 4 new steelies from folks who swapped up to alloys, but the 5th may cost you, watch out for that.
semlin said:the backspacing is 4" instead of 4.5" stock so you will get wider tracking which is good. according to BFG anything bigger than a 275 tire requires an 8" rim . some have pushed the envelope without problems, but you might end up with a warranty issue and you also could get premature wear from crowning.
