Trying to decide if I want to go one tons or not and the decider is going to be if I can get away with the driveline angle from the stock 92fj80 tcase to the 14bolt? I am thinking the stock tank would still work cause the 14bolt pinion is offset to the passanger side enough and I don't think the angle would be too much different then stock, but I don't want to tear the axles out and stick the tons in only to find the driveshaft is hitting the stock tank and then have to buy a 1000 dollar rear tank not knowing if it will vibrate like a mofo at speed. This is going to still be drivin on the road alot. What do you guys think? I would stick with stock axles, but they are non locked non full float and would need upgraded anyway and I already have the 1tons and they have better brakes are stronger and will add width and stability well you get the point.
