Does anyone know why the 12HT in the 60 series was equipped with a Fuel Return to the tank for the injector spill line? The 2H seems to cope fine with the return line being plumbed back into the lift pump inlet.
I believe it was done to keep feeding cool fuel into the pump as opposed to it heating up from continually circulating back into the pump. I'm pretty certain most of Toyota's diesels had the return
The 2H pump is virtually identical, the injector spill line is fed right back into the priming pump.. I dont think its a cooling thing, thats largely a Common Rail issue I beleive.
I think it's only the fuel pumps in rotary IPs that need the cooling.
So I differ in that here I think it is done to allow small quantities of air-contamination to be automatically purged out (by being carried back to the tank) and to allow much easier restarts after running out of fuel.
Very interesting. Is that the prime pump or main pressure pump?....
I figured the fuel return was a good feature for air purging, but wondered why it's only on the turbo engines I've seen.
