Hi all, couple questions for the experts:-
I have just about finished a rebuild of a 12ht which came out of a 60's coupled to automatic transmission.
It's going into my FJ40 which currently has a 2H with a manual gearbox and with the matching wiring loom to suit the 2H (I did the 2H install a few years back)
Questions are,
Is the 2h manual transmission flywheel the same as a manual 12ht flywheel? as I cannot use the 12ht automatic flywheel.
Can I fit the EDIC motor from the 2H ip to the ip pump of the 12ht
The 2H uses glow plugs and the 12ht uses a heat screen, question is, the glow plug relay timer on the 2H wiring loom, can it be use on the heat screen, its the same voltage and timer would be the same time in duration length I would guess.
Thanks
Questions are,
Thanks
