Is it acceptable to drive with webasto running continuously?
I don't think it will be that fast a lot more water, mass etc. To heat up... You'd better just give it to me for my Volvo TGB 1314 camper project!I think running both a water heater and air heater is overkill unless you build a camper rig where you sleep during -15ºC and below.
I know 30kw is way to much, but think of this. Instant heat in 5min!
Bought it used from a big diesel locomotive![]()
Just reread your piping, sounds right... Your Webasto heats the cab and engine fine, right?
The issue is that you can't keep it toasty when the Webasto is off and the engine is on, right?
If the above is correct it sounds like you don't get adequate flow when the Webasto is off and the engine on. This could be because of the inherent resistance in the Webasto and pump. Water always travels the path of least resistance and the longer lines, bends, pump and the internals in the Webasto might reduce flow too much to produce adequate heat?
Your rear heater is plumbed like originsl, without added restrictions right? How hot it the air from that?
