100 Series General Tech and Classifieds (11 Viewers)
Garage door is on order.
Selfie of my loaded 100 with some heavy wood on the hitch hauler and a ton of camping gear with 860 rear springs.
Looks like I need those 866 variable rates after all
Hey Mr Vain-
Get slee springs. He's got them dialed in just right.
He needs to crank TBs and it's on my to do list also. (Just need to reindex this time)
Christo has the spring height set perfect for 1/2" rake with heavy bumpers.
If you are not running the steel bumpers, skip these springs
I have the same rear bumper as yours and the front was set up by Slee to run these 34's.
The wood was the key. I had the same load on the return trip and it was level.
Rode better both ways than unloaded. If I didn't use 3rd row I'd put drawers back there for the weight
Where did you buy yours? What accessories did you get?
Bought it from here, they had a free shipping on everything special going when I bought it.
http://www.frontrunneroutfitters.com
I bought the hi-lift mount, the fishing pole brackets, and a couple of mounts for led lights. I'm about to buy the awing mounts for my new cvt awning.
The must have accessories are the tie downs and the 'stratchets.' Bought a dozen tie downs for obvious reasons but initially only a pair of stratchets. After I used them tho, bought two more pair. They are expensive, but slick.
I'm coming to Jackson wed (I think) if you want to check it out.
Club meeting is Tuesday night. You can make it!
