I need a interior roof bow, and left front blinker. Shipped to 81435.
Thanks,
Brandon
Thanks,
Brandon
Thanks,
Brandon
How about the cross member, tranny transfer?
I'll take the left turn signal if 89yotanut can't use it. I just really need the lens.
Parting out a Jan-76 mfg FJ55. This is a ranch truck from Montana that shows 77k on the clock. Rigger and I picked up the truck for the factory disc brake wheels, 4 spd trans/transfer, and disc brake front axle. The rest is up for grabs. As you can see in the pics, most of the body is beat, although with minimal rust. Rear passenger doors are useble, interior is shot, Dash controls are mostly intact, dash pad and glove box are useble, hood is useble, frame is clean/no significant rust. 2F is mostly complete, missing smog pump, alternator, and air cleaner. Motor turns over effortlessly, oil looks like it was just changed. This vehicle has been sitting for around 18 years. There is a thread in the FJ55 Preservation section showing the recovery. Rig is located in Sheridan, WY. Delivery to Billings MT can be arranged. All parts will be tested prior to shipping.
Gauge Cluster $50 sold
Dash Pad $30
Glove box door $10 Sold
Switch panel with radio and heater controls $60 Sold
Rear Axle $100
Springs $25 each REARS ARE BENT
Steering wheel $30
Steering column $25
Dome light assembley $10 Sold
Drivelines $50 each
Rear Heater $75 sold
Front heater $25
Front heater blower motor/housing $30 Sold
Heater Ts and rear lines Sold
Brake master and booster $100
Coil and Ignitor $50
Windshield washer bottle and pump $25
Radiator overflow and bracket (no lid) $20
Rear passenger doors $35 each
Hood $25
Side apron vents $10 Sold
Headlght rings $10 each
Patch panels $20 each
2F motor $500
Complete rust free frame $300
Steering Box (No P/S) $50
Front, passenger, and cargo mats $35
Parts listed in the first post are still available. Fired the motor on this a while back, ran great, but no oil to the top end. This had a head rebuild by the prior owner and they apparently never got it running. I suspect the head gasket is on backwards. Great frame, not rusted or pitted.
