1/75-7/80 Accelerator Throttle Linkage Assy. KIT Form FJ40LV-KCJA FJ40LV-KCJK FJ45LP-KK 2F Engine Assembly Instructions and Technical Overview Video (1 Viewer)
ToyotaMatt
Factory Focus-Point Mind-Set Approach
Supporting Vendor
GOLD Star
EAST COAST
Website
vintageteqparts.com
1/75-7/80
2F Engine
NOW ALSO :
9/72-7/80
FJ55LG
FJ55LG-KA
LINKAGE Home Base Too
I'm not finding the kit on your web site. Link?
Also, are the spring steel "smash on" clips incuded? Same question for the hair pin/washer/sleeve bits. Thanks!
EDIT: Nevermind. I found it. 👍
This is TECH and a TECHNCAL Video Resource thread ONLY
ill PM you to further discuss ...........
thanks matt
Hi Numby .... :)
here is some past work and linkage PORN too ...
HOW To CATCH a 4/77 FJ55LG-KA
Part # 78060-90356
Call OUT # 78103 , ROD SUB-ASSY, ACCELERATOR CONNECTING, NO.1 2/76 - 7/80 ALL NOS Parts WILD UNICORN that did not exist on planet Earth only
Minutes Earlier in UNDER 30 Minutes ?
For : @
jestlurnin :D
Eazy Peezy that's how :
- first you confirm the correct LENGTH Balls Sockets to Balls Sockets CTR. to CTR. Length in Millimeters VIA your Archived FJ55 78103 RODS measurements PHOTOS
you took 9 years ago for some reason i can't recall other then it was fun at the time like shown above with OEM METRIC STEEL RULE SST ....
- then take a NOS FJ60LG-KK 78103 ROD that's Longer a TAD by 40mm or so and CHOP its FIXED SOCKET Heads Clean off carefully
- Then start Chasing the Correct Thread Pitch and Diameter 5mm x .80 Trusty Sears Craftsman DIE down Approach 55mm with full synthetic threading cutter fliud drops at each few turns
- spin OF the Threading DIE jack Flash quickie like
- now , Take a NOS FJ40 shorter sacrifice 78103 ROD and remove its smaller top head by hand NO chopping off with grinder here
- carefully engage your fresh cut 5mm x .80 sharp new male threads onto the new female section like so
- Presto :
- 78060-90356 NOW LIVES ONCE AGAIN ........
and most importantly has been well documented Here On MUD for future generations of FJ55 Owner Operatiors to refer to VIA the ADVANCE SEARCH FEATURE Options .......
TECH step by step photos Below in order of events outlined above :
@ToyotaMatt thank you so much for knocking this outa the park. Not sure most folks understand your commitment to the cruiser world and vast freakish knowledge of all things vintage TEQ. Can’t wait to go office space on the weber currently on my 55 and see all your bling bling under Marges’ hood.
🍻 to you. Rolling rocks in me if we ever cross paths.
Thank You For the kind words Nik .....
i took a moment and pushed ever deeper into the TECH on LINKAGE in General
Please Enjoy the show
matt
