1,163,000 kilometers
Gulfport Florida
722,776 miles
Motor is coming out.
Coming out for a rebuild? Coming out for a swap? Has it ever been rebuilt? DETAILS PLEASE.
Not sure yet what failed, suspecting a middle journal or something not catastrophic, sounded like a bunch of squirrels shaving acorns. Parked it and walked away for a good long while.
Not ever rebuilt and the head has never been off.
Rebuild is the choice.
So you're saying the valves have never been adjusted either?
super impressive the mileage out of the engine! And your going for a rebuild instead of a different engine, wow.
Was this a de-smog motor or not? I ask because my 3FE was completely locked up due to the EGR and poor oil change habits.
Last nut removed, motor is ready to lift out.
Thanks to gimme a 60, I never knew there was an access opening on the tunnel, carpet had never been out.
Damages caused so far:
broken stud exhaust manifold to pipe.
Tore off the ear on one of the heat shields.
and one surgical cut on the top left side of the core support which will heal nicely.
Axles rebuilt? How many power steering pumps and AC compressors and alternators?
I bet that driver seat is toast!
Any rust?
One A/C compressor
0ne radiator, one water pump, an idler now and then
Power steering pump is original, drained and refreshed fluid several times and cleaned the screen maybe twice
Multiple alternators, Toyota alternator is the only one to use
Busted trunion bearings a time or two, but no axle issues, clean and repack the knuckles every few years
Drain and refresh the diff's every few years along with freshen the transmission fluid about a quart and a half every oil change
One A/C compressor
Damn I have replaced my radiator, water pump, idler, rebuilt my transmission, and new power steering pump already and I am at 190K miles only. I expect the alternator to go bad in the next 5 years (runs great now).
