GregS said:
O.K. guys, I've read most of the posts regarding this subject and have gained some useful knowledge. Thanks to all. With that said, maybe some of you with more experience and know-how than I with vehicle electrionics can advise me. I've got a 1982 BJ42 3b 24v all original cruiser that I will be installing a stereo system in. I need a clean (constant for memory functions) 12v source of power for the stereo and amp and will also be wiring my existing cigarette lighter to 12v for charging a cell phone (I've purchased the 12v lighter to replace the existing 24v). I would like to avoid any of the unbalanced draw down issues between batteries. It's got two brand new batteries installed. My typical tendancy is to over build. Assuming that I keep this truck in it's original trim (I will) and not turning her into a trail only rig with multiple power hungry draws, what's my cleanest most efficient option(s)?
Pimp mode?
Use a Solar Converter for clean efficient power, 24V-12V stepdown. IMO, one of the better ones out there. If you want to load balance when running, or turn on/off the load balance then check this thread:
https://forum.ih8mud.com/showthread.php?t=33070
Out of pimp mode now...
The BEST way to get 12V is to run a seperate alternator, to an isolated deep cycle battery, and take all your 12V needs off that. In reality, this is not easy for many, and not an easy install, otherwise you would see it all the time.
The 2nd BEST way is to use an isolated deep cylce 3rd battery, fed from a step down converter. Have the fed going from the converter on a HD relay which is hooked to a monitor, so it shuts off when your starting batteries get too low. Or, simply hook up the feed from the converter through an ignition powered relay. Take all your 12V needs off the deep cycle battery, and Bob's your uncle.
The 3rd best way is to run a load balancer 24V-12V converter which feds through to a fuse strip for your 12V needs, wire your memory and constant 12V need supply needs straight up, and relay anything you want ignition switched. Then....tap into the 12V feed line in the engine bay through a HD switch as Stone has done, or a HD relay has I have done...to go in and out of load balance.
The 4th best way, and some might say the 1st best way if your 12V needs are minor (below 20amps) is to run whatever converter you get in strict 24V-12V convert mode, to a fuse strip. Then relay whater needs to be ignition power, and run the other needs hot all the time.
hth's
gb
