I am in the process of swapping out the drum brakes on my 1970 fj40. I am also replacing the stock birfields with Longfields. The problum is the Longfield is about 80 thousands larger in diameter then the original Birfields that went with the drum brakes. Clearly I need to do some grinding but I'm not sure where. Can I remove some material from the Longfield, fromm the inside of the axle housing or both???
