alia176
This will be the third seal that's going in on the driver side front axle! The second one was from Marlin kit so I thought maybe it was a fluke! Now, I'll be doing my third birf repack this weekend with the oem seal.
When I take this seal out, I'll take a close look at the wear points. If it's on the bottom lip of the seal, then the axle is no longer centered and I may need to reshim the knuckle housing. IdahoDoug, hurry up and come up wth the shim thickness, will ya ?
Anyway, why is this happening on the driver side only? I'm also thinking perhaps its due to the locking hubs? Perhaps the driver side axle is "walking" axially and the seal is not riding on the smooth surface of the axle? I'm using two snap rings to center the stub axle. Incidentally, I think the leak is worse due to Redline Synthetic diff oil. Before, I had birf soup but drip drip on the rim. But now, it's really bad!
Recap:
109,460 replaced both oem seals with Marlin kit seal (all seals replaced plus wipers)
115,870 replaced driver Marlin with oem seal
134,5xx about to replace the driver seal again with OEM
Anyway, here're some pics to illustrate. The first one is the driver, then pass, then the driver tire.
Thanks for any inputs and TGIF .
Ali
Recap:
Ali
