I changed the starter contacts today, just to let you know how I did it.
All done from wheel arch.
Removed front wheel (starter side) pull off the rubber water guard, remove auto box dip stick, undo the two screws that hold the auto box dip stick in place, one on inlet manifold and other just below starter motor, leave the two small hoses connected! then just pull upper out of the lower half of the dip stick and move to one side and push a small bit of tissue into the lower half of dipstick to stop debris entering the auto sump.
Remove the + terminal off the battery, then remove the two connections on starter motor, one is a push connector and the other is secured with a nut and washer.
Remove the two bolts that secure the motor to the bell housing, I used a 17mm open/ring combination spanner, I put the ring end on the bolt head and used a 19mm ring spanner on the end of the 17mm so to use as leverage, sounds confusing if you have never done this, but just put the ring end of a spanner on the open end of a spanner and try it, it works great, then remove motor out through the wheel arch area.
Then just remove the plate/cover which is held with three small screws, the rest is quite easy, just remove the contacts and replace as they were removed, just before you fully tighten the contactor bolts, gently tap down the contacts so they are flush with the inner of the plunger housing, flat/level.
replacement of the starter is just the reverse of removal.
Like I say all can be done from the wheel arch area, it really is quite a simple job to do.
Tools needed are....
10mm spanner to remove batt terminals.
12mm to remove auto box dip stick tube.
17mm open ring plus 19mm open ring (leverage spanner) for starter housing bolts.
14mm ring spanner for terminal nuts.
8mm ring spanner for contactor cover
It's probably better to purchase a new plunger as well as the contacts, as this wears too, but I just rubbed flat with emery paper, but if I had known, I would have replaced plunger too, if it plays up again, I will replace all parts.
