8/1/05 I have sold most of the parts on this list. The parts that I still have for sale are posted in a new listing, heres the link:
https://forum.ih8mud.com/showthread.php?p=595842#post595842
I might be able to refer you to the person I sold them to if it was something sold in a lot.
First I would like to apologize to anyone I have not yet responded to. I will try to do so today. I am in the middle of moving and have a lot of projects that I am working on. This is also the busiest time of year for my landscaping company which means long hours leaving me exhausted at the end of the day. I told myself that I can’t have another Cruiser until I sell off the parts I have. I’m offering to sell the remaining used parts in one lot. If you don’t want this many parts, maybe you can go in it with a friend. I need this stuff gone in the next 30 days, I do not want to have trash to dispose of, and it’s up to you to get rid of what you don’t want. You have to remove it, I can't ship it.
After you buy the lot, if it is all removed to my satisfaction, I will give you a new set of Alcan 5” FJ40 lift springs for free.
This list is as accurate as I can make it, I’m sure its leaving off a lot of small parts I don’t know I have, but I think the big parts are all listed.
$1500 for all of it.
Axles and driveline.
2x 4spd transmissions with transfer cases.
4spd transfer case disassembled
3spd transmission with transfer case
3spd transmission rebuilt
3spd transfer case disassembled
3spd bell housing
2x 4spd bell housings
Pair of 3.70 differential 3rd members rear has a little play
One 3.70 ring and pinion gear
12/76 brake booster great condition
9/74 brake booster
One pair of front and rear 77 FJ40 drive shafts, excellent condition
4 31x10.5 tires mounted on 15x8 wagon wheels, tires worn
4 31x10.5 tires mounted on 15x8 chrome wagon wheels
4 15x8 wagon wheels
15x10 wagon wheel
4 odd tires
Stock FJ40 drum brake wheel
Several (3x4spd and 1x 3spd?) good clutch, pressure plates and flywheels
One or two more flywheels
4spd transfer case shifter linkages
U bolts and spring plates
Several sets of stock FJ40 springs, 2 pairs in known good condition
Several shackles and frame pins
FJ62 hub caps
FJ60 rear hub caps
3spd flywheel cover
Body parts.
77 FJ40 hard top disassembled good condition
77 FJ40 hardtop fair condition
78 FJ40 hardtop needs work
74 FJ40 hardtop needs work disassembled
Parts to another hardtop
2 77 FJ40 gas tanks
Several FJ40 gas tank covers
Several FJ40 transmission tunnels
Several pairs of FJ40 hood aprons
2 FJ40 grills and bezels
74 FJ40 hood
3x 77 FJ40 front doors need rust repair
2x 77 FJ40 ambulance doors need rust repair
3x pre 74 windshield frames good condition, one has broken glass
78 FJ40 stock roll bar, only year of black roll bar with seatbelt mounts
2x pre 74 tire carriers
77 FJ40 jump seats need recovering
72 short FJ40 jump seats need repair
70 large FJ40 jump seats need recovering
2x 79 FJ40 front seats some rips in seats, one pair missing rails
One 77 front seat needs recovering
One 77 jump seat needs recovering
2x glove box doors
2x 77 consoles
79 console
Nice 77 FJ40 rear mat
1 or 2 FJ40 front mats with some tears
Late model interior door panels
77 FJ40 seat mounts
Most parts from a pair of FJ40 ambulance doors
3x FJ40 pedal assemblies
9/74 FJ40 rear upper door supports
79 rear heater
77 rear heater
77 front heater
77 front heater missing core
FJ40 bumperettes
FJ40 front and rear license plate brackets
FJ40 sun visors need recovering
Several FJ40 radiator splash shields
Several FJ40 skid plates 8x? 3spd and 4spd
FJ40 rear light splash shields x 3
5? FJ40 windshield washer bottles
Several coolant overflow bottles
One 79 FJ40 coolant overflow and washer bottle bracket sandblasted and painted
Early door strikers
2 FJ40 battery trays
Box of rear view mirrors
Box of interior parts, dash plugs. Ashtrays, defroster vent tubes
Engine
Early non USA carburetor with low miles
2x 77 carburetors
79 carburetor
76 carburetor
Another early carburetor
Complete emissions equipment off 79 FJ40
Complete emissions equipment off 77 FJ40
Some emissions parts off a 74,76,77,78 FJ40’s including
3x charcoal canisters
2x vapor separators
74 ECM
Various carburetor linkages
Aftermarket air filter housing
4x 2f air filter housings
2x F air filter housings
Early distributor with octane adjuster
79 distributor
3x 77 distributor
Another distributor
3 coils with igniters
Couple of other coils
79 Alternator
5? 77 alternators
GM alternator
Several water pumps
Several pre 77 fuel pumps
2 starters
8 various manifolds
One 79 intake and exhaust manifold in great condition
79 alternator bracket
Complete 77 FJ40 exhaust
79 FJ40 header pipe and cat
Early engine fan
Several t-stat housings
79 oil cooler
3 radiators that need repair and supports
Dash controls and electrical
77 FJ40 front wire harness badly burnt good for connectors
77 FJ40 warm pull
77 FJ40 fresh pull
9/74 FJ40 Fan switch
10/78 FJ40 Headlight switch
9/74 FJ40 wiper switch
9/74 FJ40 dash brake light
77 FJ40 fuel tank sender
9/74 FJ40 hazard switch
77 FJ40 wiper switch
77 FJ40 heater control light and bracket
77 FJ40 fan switch
12/76 FJ40 fan switch
77 FJ40 dash light with bracket
9/74 FJ40 seatbelt buzzer
77 FJ40 cigarette lighter and socket
FJ40 interior light. No door position
FJ40 brake and seatbelt light
FJ40 inspection light socket
77 FJ40 fuse box cover
FJ40 oil pressure sender
FJ40 water temp sender
Several good FJ40 turn signals
Steering
FJ40 steering box, pitman arm, centering box, tierod setup
FJ60 or 62 PS pump and bracket
Other
Universal tow bar from U Haul
Universal tow hitch from U haul
Large Sand blast cabinet
Large Ammo can
Disassembled York air compressor
3spd bell housing
9/74 brake booster
4 15x8 wagon wheels
15x10 wagon wheel
4 odd tires
FJ62 hub caps
FJ60 rear hub caps
3spd flywheel cover
Body parts.
2 77 FJ40 gas tanks
74 FJ40 hood
2x glove box doors
2x 77 consoles
79 console
77 FJ40 seat mounts
79 rear heater
77 rear heater
77 front heater
FJ40 bumperettes
Early door strikers
Engine
2x 77 carburetors
79 carburetor
76 carburetor
2x vapor separators
74 ECM
79 distributor
3x 77 distributor
Another distributor
79 Alternator
5? 77 alternators
GM alternator
Several water pumps
2 starters
8 various manifolds
Early engine fan
79 oil cooler
77 FJ40 warm pull
77 FJ40 fresh pull
77 FJ40 fan switch
Steering
Other
Large Ammo can
