Where is it?????
Will someone post up some headlight swap information with part numbers?
Thanks
Thanks
It would seem that replacing the low beams are the way to go not the high beams. If I recall, the change is greater i.e. more notiecable in the low beam swap. My brights are perfectly fine in my opinion. But I got uses to zenon bulbs in my last BMW wagon and I have never experienced better low beam lighting that in that vehicle. I would like to try the low beams to see the difference. Logically, there has to be a difference.dnp said:Hope y'all have better luck with the HIR's than I did. I bought the HIR's for the high beams in my LX and one of the bulbs is gone after only 5 months....unless I got one bad bulb, I'd question spending the money, as they don't seem a whole lot brighter than what was already in there....................
SINCITY100 said:I have seen WAY too many situations where some (higher wattage) bulbs have blown fuses, or even melted (or otherwise damaged) the connectors or wiring directly behind the bulbs over a short period of time.
Low beam stock: 9006, 12.8V, 55W, 1000 lumens
Low beam new: HIR2, 12.8V, 55W, 1875 lumens
High beam stock: 9005, 12.8V, 65W, 1700 lumens
High beam new: HIR1, 12.8V, 65W, 2530 lumens
aedgington said:What does the "plus 30" and "plus 50" signify?
There is a partnumber for OEM HID headlight unit in the 2000 parts catalog for General Area Version:Jukelemon said:Where is it?????
Thanks
Pretty much everything you want to know about HID and 100's has been discussed in this thread...
https://forum.ih8mud.com/100-series-cruisers/358539-hid-installed.html
