I've been wanting to adjust my timing, or at least see if it's ok but I'm running into a strange problem. If I leave the two vacuum hoses connected to the distributor I can see the timing mark at 13-14 degrees. However, if I remove and plug those lines as mentioned in the FSM I can no longer find the timing mark, even if I step through all 180 degrees on the timing gun.
Secondly, I loosened the bolt at the base of the distributor but the darn thing won't budge even if I tap it with a hammer.
Any help would be greatly appreciated.
Ray
Ray
