LX 600 Aftermarket Wheel Choices (2 Viewers)
JAOS TRIBECROSS 20x9.0J 55 6H139.7 TITANIUM GOLD WHEEL B952090TGD
Nokian Outpost nAT 275/60R20 115H
At normal height and max turn Ican put index finger between uca and tire.
Should i ran stock pressure 33psi?
View attachment 3540110View attachment 3540111View attachment 3540112View attachment 3540113
If the Nokian's are rated as an LT (Light truck) tire, then I would expect around 40psig is the target inflation pressure.
For example my BFG KO2 require about 41-42psig to be properly inflated for the same load carrying capability as the factory "passenger" tire.
There were 2 choices for nokian outpost nat in this size i have installed one with lower load rating and weight
Speed Rating: H (130 mph)
Max Load: 2679 lbs
Max psi: 51 psi
Weight 46.3 lb
Vs
Lt one
Speed Rating: S (112 mph)
Max Load: 3417 lbs
Max psi: 80 psi
Weight 52.9lb
Max Load: 2679 lbs
Max psi: 51 psi
Weight 46.3 lb
Vs
Lt one
Max Load: 3417 lbs
Max psi: 80 psi
Weight 52.9lb
In this case, you're probably good at the OEM inflation pressure.
Those look awesome. Love those JAOS rims. Nice to see 34's fitting! I'm going to try Falken Wildpeak AT4 in 285/70R18 (34") too once they're available.
FWIW, I use this site for tire pressure recommendations. It's saying you could run as low as 26psi (if I put all the info in correctly) based on load rating but I wouldn't go below 33psi.
Yes tire pressure sizing in calc all correct numbers. I will set at 33. Shop did 36 and it seemed a bit firm but not as firm as e rated ko2 at same pressure. As far as diameter please note p rated is 33 inch tire whereas e rated is 34! In the same size! Apparently e rated has deeper thread according to spec. I can confirm that p rated 275/60/20 on 55 offset fits with around 10-15mm distance to uca
Are the 18’s E rated?
Those are not but they use a shallower tread depth compared to the other NON OE and AT4. They are very light though, like 37-38lbs which is perfect.
I called Sumitomo and got all the specs. They were built specifically for Toyota OE use.
The next one to look at would be to the Yokohama in that size but it weighs like 46 or 47 lbs.
UPDATE: I gave the Vossen HF6-4s 30 offset a try. I installed Continental Terrian Contact A/T 275/55/20 on two wheels and mounted them to see how far they stuck past the fenders. There was some slight poke (see photos) but not as much as I expected.
I then asked the tire shop to mount the Continental Terrian Contact A/Ts on the JAOS 20-inch wheels with a 55 offset. The JAOS Tribe Cross wheels fit perfectly and did not stick out past the fender. I could have gone with a 285/55/20 tire, but Continental doesn't make this tire in that size. I spend about 90% of my time on pavement, usually in light mud and gravel when off-road. Therefore, I didn't need to go with an aggressive all-terrain tire. My goal was to keep the ride quality as close to stock as possible.
I am pleased with the fitment of the JAOS wheels. JAOS only offers the wheels in two colors: Matte Gun Metal Metallic and Titanium Gold. The Matte Gun Metal Metallic is darker in person than shown on the internet. I prefer more of a BMW Silver Color and wish that would have been an option.
The JAOS wheels come with two different offsets. The 55 offset is for a vehicle without fender flares, and the 38 offset is for an LX with flares. I had to order the wheels from an online retailer located in Japan. If you want to order these wheels, please send me a message, and I will provide the retailer's name.
I am selling the Vossen HF6-4s with the 30 offset at a discounted price. The Vossen HF6-4 is a complete set of four wheels with all hardware (Vossen Center Caps, Vossen Lug Nuts with a wheel lock). Two wheels had tires mounted, but they never saw any road use. They will come in the original boxes, and I will ship them. The price is $2,300 shipped in the contiguous USA.
Great looking wheels and thank you for the tip!. I just bought the same sets and my dealer is telling me that the OEM rug does not fit (too large). What did you use and what were the dimensions? Thank you!
Just to be clear, I got the JAOS wheels
These look great! My Lexus dealer is hard time installing these jaos wheels since the OEM rug nets are too big to fit. What did you use for yours and where did you find them? Appreciate the advice!
I bought mcgard 1.5x14 spline drive lig nuts. Yes oem nuts are different they are flat while aftermarket wheels need conical seat. I picked black ones and they look great. McGard 65515BK Black Spline Drive 5 Lug Wheel Installation Kit (M14 x 1.5), 16 Lug Nuts / 4 Locks / 1 Key / 1 Install Tool https://a.co/d/4fovS8Xhttps://a.co/d/4fovS8X
Thank you so much for the fast response! Just ordered these!
Get some extra. 6x4 =24. You can find a separate set of 4 lugs. Also LX600 wrench is 21mm (lc200 wrench is 22mm) and spline drive for aftermarket lugs is also 22mm(I used one from lc200). If you carry extra oem lugs for spare OEM tire you can get combo wrench and keep it in the wall next to jack. EPAuto Telescoping Lug Wrench, Wheel Wrench with CR-V Sockets (17/19, 21/22mm) https://a.co/d/dEwhBI3
Have people in the Middle East found a way to make the LX600 less ugly, do they just use ARB bumpers?
We don't view it as ugly as you guys do.
The GX 460 now that is ugly.
It could be better, yes. However, when its such a common vehicle and have been seeing it in large numbers daily for almost 10 years with a big grille (since 2016 update debut in end of 2015) that it doesn't seem offensive to us.
The 460 is definitely less attractive. No split tail gate on the 600 is the kick to the balls.
If anyone is interested I have the Vossen HF6-4s 30 that I purchased from ElvezTX in the beginning of this thread. I ended up never mounting them and have since sold my LX600. They are taking up room in my garage and would give a sweet deal to anyone that would be interested in them. I have everything, including, lugs, and TPMS.
