All,
Recently picked up a 95 JDM Surf in great shape. Beyond fun to drive, and over the moon with it so far. However, I can't keep things to stock, and need a project so here we are.
My idea here is to make this a guide for newbies to the 1KZ engine, like myself, to learn what to look for and what to do to make these engines go the long haul. Not a bee all end all thread on making the most power from a 1KZ, but the little upgrades that will by nature help the little engine out and keep heads from cracking.
The project is a bone stock '95 Surf KZN130 straight off the boat from Japan to the land of Hank jr. and Freedom. Unfortunately, we weren't free enough for Toyota to send 1KZ's our way, so we had to wait, and that means parts can be a bit of a PITA and aftermarket support is somewhat limited. Despite being a HD mechanic by trade, there are nuances to each engine and application, and in the case of the 1KZ I am a bit over my skis in that department. A couple of good forums out there, but no truly definitive answer that I have found, so let's make one.
The goal is to make her last, do some tasteful upgrades that keep things relatively stock, but reliable, and can be used as a jumping-off point for guys who want to go further down the power rabbit hole.
From what I understand these engines do not like too much heat and high EGTs, as head cracking is the Achilles' Heel, so starting there with a bone stock engine, here are my thoughts. Feel free to educate me, there is a reason I'm posting here.
Adds
- EGT and Boost Guage
- 11 blade fan upgrade
- lower temp thermostat
- New exhaust custom built because the stock one is crazy restrictive with 0 flow, there is no shot I will pay 600 freedom coupons in shipping from AUS, welding is fun, and smiles per mile
- Possible Intercooler down the line
- Maybe a new Rad depending on how cool things stay
Questions
- A less restrictive exhaust with lower backpressure and more flow will in theory raise boost pressures slightly. With the ECU fuel cutoff at a factory 15psi, will the sole addition of an exhaust put a stock 1KZ over that, thus requiring a boost controller or tune?
- Air to Air or Water to air cooler?
- Overall "happy" temp range for 1KZ?
- Any luck with the "hoot" method of installing an EGT guage where it should be on the manifold without removing the turbo?
Full disclosure, up in NE USA where we have some wild temp swings, but this car is a sunny day driver in the summer mostly, so banking on anything from 50-100 dungarees frankenstein ambient temp.
Any info is appreciated, some of you know way more than I ever will about these engines.
Adds
Questions
