Hey guys, I've read this board for years, but haven't posted much in the past as I only recently (last month) became a proud FJ62 owner ('88 that I bought off MUD).
This past week, I've noticed some issues when starting the truck, having to crank it a few times before the idle will hold. Earlier today, I was driving at low speed on a neighborhood road and the truck stalled. I got it off the road, but then had to try numerous times over about 30 minutes to get the truck to hold idle and drive. I was able to get it home and read as many only threads as I could find to try to figure it out. Here's what I've done:
- Checked the Fuel Pulsation Damper -- I still have the screw intact and it seemed tight/in place
- Diagnostic Check -- I got the Error 51...which led me to the TPS
- Resistance Check on TPS -- I think I'm running pretty normal. I get a reading (around 12 ohms) when closed and it goes to OL when I open the throttle. I'm checking as per the FSM across IDL-E2
- Did a quick visual inspection of all hoses and connections under the hood -- I haven't done an exhaustive search, but everything seems intact.
After doing the above steps, I didn't clear the Error 51, but the truck does fire up and seems to idle ok. I drove around the block and again had a stall issue. I couldn't get it started (again), but was able to pop the clutch (H55 conversion) to limp home a few feet at a time. I did notice that when I attempted to hit the throttle to up my RPMs it would still stall...like pressing the gas pedal had no effect on preventing the stall.
Edit: I've also discovered that I can prevent the idle down / stall on starting the truck by keeping the starter engaged (turned). If I keep the ignition turned by holding the key it will idle and rev RPMs without issue. The minute I release the key it idles down and dies.
Any ideas? Thanks for any recommendations, this place is awesome!
