- Thread starter
- #21
Can I see a picture? I'm having a hard time envisioning where you are.
Absolutely!
Here is an image from underneath. As you can see the axle is sticking out pretty far from the diff. This is where I am stuck. I can't seem to generate enough force to push the axle into the diff past the snap ring.
Right now I am going to try and back this out, line the snap ring with the opening facing the bottom as advised by @abuck99, and force it in as far as I can. Then i am going to try and tap this sucker in using a piece of wood on that little lip there.
However, that may take a month of Sundays to tap that all the way in so if there is a more efficient way to do this I am all ears!
