Does it rub when flexing?Icon with other goodies. 35x12.5x17
We have a club member running 35's on a 200 series using tundra front end parts and all I can say is it looks AWESOME!
6" lift....gosh it is hard enough to get in the LC with the 2 - 3 inch lift after a leg day at the gym......count me out.
Plus a 6" lift wont fit in my garage, forget it for me.
Plus it would end up looking like those damn Fords and Chevy's that drive around here in Southern Cali. YUCK
And kdss works proper and all?View attachment 1189731
200 Series Lift using Tundra front IFS and Icon shocks
here is the link to the tread I did outlining the tundra suspension swap. Brian Jowett did it first, I believe I was second, and two others have done it since I did.
could have fit 35's. decided to go with 285/75/17. little less weight, narrower, hopefully better mileage. love the tread design. Love the way it drives, and there's still tons of room left on the coilovers if I wanted more height.
Nice!, and how many inches lifted?yes works great. the angles of the linkages from the lower control arms to the sway bar ends are not optimal, but it works. I swapped out the passenger side land cruiser linkage for a Tundra linkage. couldn't feel any differenct, but the angle was a little bit better.
do the tindra and 200 share the same spindleIt should fit fairly well, the spindles will be a bolt on, the drop brackets should be a bolt on... but I'm not 100% on that one....
so logically the total chaos tundra spindle gussets will fit my lx570?Yes, the spindles are the same.
