I'm just starting to look into this and at this point haven't had the time or motivation to look on the FJ40 section or the archives. In case you hadn't heard the rumor yet, I was the lucky winner (or victim - depending on your perspective) of the Dave Aley Free FJ40 Lottery. He had mostly finished the springover conversion using massive U-Bolts and almost as beefy channel plates as the top plates. I'd like to know people's experience or words of wisdom doing a springover on a 40. I've noticed some posts where people have done a knuckle turn to reduce the driveline angles, alowing them to tilt the differential a bit while maintaing the original steering/pivot geometry (caster ?) at the knuckles for good steering and control. I don't know if I want to tackle this unless it really is the smart way to go.
Also, I need to put new shackles and bushings on it. I've seen and heard of greasable shackles which sound better than non-greasable ones. Anybody got any advice there? The first priority for me is to get all the springs secured to the axles and frame in a relatively aligned manner so that it can more safely be pushed around without the axles trying to go off in different directions than the frame.
I need to put some matching tires on it that will hold air as well. I'm not ready to fork out the money for some good tires until the truck is pretty much put back together with a good engine and drivetrain in place. So I was thinking about going down to Discount or Big-O to see what used tires they might have for 'cheap'. I figured something in the 31" - 33" range would be fine for now and probably not too hard to get.
I'll work on getting some pictures up later, after I actually take some. Then Paul and Rudy won't feel so bad about the condition of their projects.
especially over bumps. Also I would figure out which steering setup you're going to use. I've reinvented my steering several times getting it were I want it and now I'm making longer spring mounts to clear my new high steer setup.
