Here's a link lesson I learned the hard way. A lot of people here will say "duh! Of COURSE!" ... yeah... well until I actually had metal cut AND WELDED, I didn't get it. Now I do. And it's responsible for one of the many re-re-re-do's in my project.
Here's a doodle:
In these drawings, we're looking at link mounting points from the side. The arcs are on the axle end, and the fixed points are the chassis ends.
In the drawing on the upper left, the vertical separation between the pivot points on the axle are identical to the spacing and separation of the chassis ends. The linkage "parallelograms".
That is, when the axle goes up and down (red vs. blue), the pinion angle doesn't change relative to the chassis. The pinion angle is depicted by arrows. The arrows that are in the up (red) position and down (blue) positions are parallel to eachother.
In the top right drawing, the axle mounts are the same, but the chassis mounts are much closer together. In this case, when the axle swings up and down, the pinion angle tends to point TOWARD CENTER at all times. Although this would be better for the U joint between the driveshaft and the pinion than the extremes in drawing #1, it has it's own draw backs. For a rear axle, this would be fine, but for a front steering axle, this would mean that you're throwing away your caster angle when the thing droops. This would mess with steering.
The third, bottom, illustration shows my particular screw up. I limited the vertical separation of link mounts on the axle in order to allow for the greatest possible up-travel. As a result, I ended up with the vertical separation of link mounts at the axle end being LESS than at the chassis. Because of this, the axle swings in the same way as one of those rocker-glider chairs. Just like how those chairs tip back and forth while they swing back and forth, this link geometry tips up and down as the axle swings up and down. It actually ACCENTUATES the pinion to driveshaft misalignment... a worst of all possible outcomes.
There is no adaptive reason to ever build this geometry that I can tell. The reason I bring this up is that if you're going to make adjustable link geometry by having multiple bolt holes for the chassis ends of the uppers, then you should be mindful of this possibility. You need to make sure that all of your bolt hole choices make the chassis end vertical separation less than or equal to the axle end separation. Any bolt holes that open this distance up to a value greater than the axle's is to be avoided.
