we are home - thanks you all!!!
remove the racor, try then. Hope this helps.
Do you still have the factory sedimenter mounted to the frame rail or did the Racor unit replace that?
What type of valve switches between tanks? I have a rear fuel tank mounted in my Troopy where the spare tire usually goes. The stock lift pump did a poor job of pulling fuel from the rear tank, through an inline filter, the tank switching valve, factory sedimenter and up to the fuel filter. That's a lot of plumbing for the stock lift pump to draw through.
My Troopy would seem like it's starving for fuel on boost at cruising RPMs in 5th gear. When I switched to the front tank the under-powered condition went away. I ended up switching to a transfer pump setup to move fuel from the back tank to the front fuel tank and did away with the tank switching valve. It cured my problems. I did buy a Facet fuel pump that puts out 4 psi that I was thinking about trying as a supplemental lift pump for the rear tank. I haven't gotten around to that because the transfer pump works for me.
The injection pump requires a certain amount of pressure at its input from fuel filter. If the lift pump is having a hard time drawing fuel from the tank due to a tiny leak or slight amount of gunk it might drop a few PSI on the outlet. The lift pump was only designed to pull fuel through a few feet of fuel line from the factory tank location.
i by passed the racor fuel filter and install the electric fuel pump this allowed enough fuel to flow into the injector pump. Rufusthedufus is correct the oem lift pump was not strong enough to pull enough fuel at high rpm so that the engine was starving for fuel at high rpm, that is the reason we had no problem at low rpm or starting the engine. it probably would have work if i just by pass the racor filter and connected directly to the lift pump.
in my experience with this engine getting the fuel to flow correctly has been an ongoing issue for me. here is my future plan to address this issue.
1. i will install an electric fuel pump after the lift pump and before the fuel enters the fuel filter. i will keep the lift pump connected. the electric fuel pump will help the mechanical fuel pump for the added pressure that it needs. my concern here is too much pressure for the injector pump, is this a problem? i do not want to screw up the my injector pump.
2. i will re connect my racor filter and the oem water separator. i know this might be over engineering but having clean fuel is a good thing especially in some places i might end up getting fuel. i think having both will probably be ok because the electric fuel pump will help in the needed pressure to pull the fuel to the injector pump.
3. the other option is to choose between the oem water separator and the racor filter and only install one of them.
i want to know what are your thinking of the above solution, especially it's effect to the fuel injector pump. or tell me if you have suggestion on how to improve the system.
by the way to add to the excitement i also broke my accelerator cable when we left San Felipe, so from there to home i drove the nulla with a rope tied to accelerator lever pulling the rope with my right hand from outside the window in place of a gas pedal...... this makes nulla qualify as a simple "expedition vehicle"
we want to thank you all for all those helpful diagnosis that you made all where very helpful, that is why we value greatly the ih8mud community. especially when you are on the top of the mountain and the temp outside is 24F, nothing for many of you but remember we are from Los Angeles, California where the sun shines everyday
this is not the first time and we know will not be the last.
