- Joined
- Mar 11, 2006
- Threads
- 207
- Messages
- 1,937
I swear I saw a fairly comprehensive FEA post here by Landtank (Rick). I have found a couple tidbits here and there. Does anyone have the link to his post.
Or, tell me when you mark and measure the tires are you on the ground? I assume you would not lift the wheels off the ground to take the measurements, correct? Then jack up the truck rotate your makes to the rear, measure and adjust at the the tierod (rear of the axle).
Is that basically it?
truck. We knew that I was going to take it into the mechanic and have it laser aligned anyway, so we just wanted to be close enough to get there. We didn't bother with getting the steering wheel straight under this scenario.
