OK, went on a 45 mile interstate trip... front tires where hot when I got there but no time to find out why. went on run of about 10 miles ghost town run in the trails section.
got home and I could see the front tires had worn down... oh shait...
just reference, say the back tires were 80 degrees the fronts were around 120.
so time to check into this shait!!!!
I could do.. maybe 65. and my wife was running up behind me like.... speed up. heck I had it wooded. she was at about half on the gas peddle. WTF... I have the modded motor..
got home and checked it out... 2 inches of tow in.. yeh 2 inches, I am shocked that the tires were not squealing our I could not smell them burning.
so here is how I did the aline-ment
first I cut two pieces of small angle that I had laying around to 30 inch's long (the biggest tires offered stock on the toyota). marked the middle of them.
pulled the front wheels off and clamped them to the brake rotors.
stuff that I used.
measure from the angle to a point on each side to make sure the front end is pointed straight. I used the upper leaf spring.
I also taped the two measuring tapes to the ends of my 30 inch angle iron.
then adjusted the tie rod so the measurements were 1/4 inch less in front then in back.
This worked very well.. on the last run out I felt the tires and could not tell a difference in temp.. and felt like I had gained 10 hp... I could tell a difference.
the new 36 sx's are way larger then the old SX's...
I did have a balance problem, I used to use wind shield washer fluid. but after the new tires and seeing how rusted out the rims have gotten I switched to RV anti freeze. it is non corrosive and environmentally safe.
8 oz in each tire made a huge difference.
stuff that I used.
