Obtuse free mods part uno: Door/seatbelt buzzer mod
Trumansburg, New York
While you've got the kick panel removed doing your pin-7 mod, dig deeper and higher into the spaghetti of wiring to this blue box. 10-mm deep socket, knive and phillips screw driver is all that's needed. Start to finish takes about 15 mins if you've had that panel removed more than 3 times.
whoops, resizing the rest...
no need to mess with the two philips screws, the whole board with plug end slides out. Using the knife blade again you can gently pop the soldered tabs off of their attachment to the speaker. That way you can resolder them easily if you want to return it to normal fxn. Cram it all back in and leave that door ajar as much as you please :D :D :beer:
Thank you :)
[quote author=landtank link=board=2;threadid=16647;start=msg160952#msg160952 date=1085102173]
Isn't that the thing that lets you know if you left the keys in the car?
[/quote]
No, that'd be me wee brain ;)
don't know about just unplugging it but I was going from previous experience where several other fxns were tied into that like interior lights, door ajar, seatbelt dash lamp, security system, etc. In fact in the last vehicle I had I actually soldered a resistor in there in place of the speaker. I did this while waiting for someone so I risked having something go wrong with just popping the contacts off the speaker but it works exactly as I expected. Everything works as it should except there's no buzzer. I usually have my driver's door open ALOT during my work and am constantly getting in and out, etc. so this was one of my biggest annoyances. Just thought I'd pass the info along as no one answered my original post on how to disable it.
Mike
Note to self: Don't be too hard on Mike when he rings up needing a key to get into the Cruiser after he locks the keys in it. ;)
[quote author=cruiserdan link=board=2;threadid=16647;start=msg161139#msg161139 date=1085119982]
[/quote]
He will feel a buzz in his head when he turns and see his keys in the locked car :D
Mike
Don't listen to them, Mike, this is a cool mod. I'm adding it to the list, will do some day for sure. My doors lock when I push a button on my keychain... I'm surprised the rest of you don't have that too? plus I'm sure you're forward thinking enough to attach a secret backup key to the frame somewhere.. ;)
[quote author=bkgiii link=board=2;threadid=16647;start=msg161523#msg161523 date=1085168989]
What!??? Mine's supposed to chime???
[/quote]
When the sunroof is tilted open (as opposed to slid open) and the key is removed from the ignition and the driver's door is opened.
dammit, Dan............................
OK.......send me the part that will make my buzzer perform as you described.........
I'm getting real sick of this forum......every time I think mine is in pretty good shape, somebody like Eric points out a 'feature' that supposed to be there that I check and mine don't work!!! GRRRRRRRRRRRRRRRRRRRR
so where the red arrow is in your pic is the tab you pop off?
hmmmmm.... i don't have a single chime/ding in my 80! no sunroof, no nothing.
Maybe you did this mod 4-1/2 years ago when this thread was first posted? :grinpimp:
-B-
