I thought I would post some pictures of the quarter panel patch I fabricated. This may help someone else or give some ideas. While it is not perfect it is better than paying 200-300 dollars for one from Wolf or CCOT. I simply made a poster board template, cut the shape out, and started bending/ welding.
I do not have a shrinker/stretcher, so i just cut out reliefs every 1 1/4 inches 3/4 inches deep to make the wheel arch lip. I then used a vise, vise grips, and even a giant crescent wrench to bend the taps individually. I clamped it to what was left of the existing arch to make sure I was getting the correct shape. I then tacked each gap to hold its shape.
Then it was just a matter of tacking in the rest of the gaps and grinding it down with a flap disc. For those of you with wheel arch rust in a FJ60 (which is pretty much every 60 that doesn't live in the southwest) , it may give you some confidence to try this, knowing that this was the first patch I have ever created..........and I just started welding yesterday. Take your time, this took me all day to do.
