When I put on my bullbar a few years ago, I had to pull off the stock tow hook. I put an aftermarket one on the upright of the bullbar, and figured it was good, unfortunately time showed the upright isn't strong enough to take it. The sheet steel is tweaked around the hook now from say a half dozen decent pulls.
Looking in at the hook on the bullbar
Looking down on it
Tweaked steel
I went down to SnT in November and rigged the bullbar up with a removable tow bar to bring back a second 62. While it was being swapped over to the California truck at D'Animal's place, we modified the bullbar so I could mount a pair of stock towhooks under it, bolted through to the frame with the stock bracing/brackets. I can't remember if I had been thinking about this before hand, of if it was something Dan and I cooked up while down there.
Stock arrangement
Reoriented to work with the ARB
To make it work, one new hole per side is required in the base of the ARB, and the bottom portion of the framerail. The hooks use the existing rear bolt hole of both, and a new one cut to the spacing of the hook. Having the hooks loose and handy, and access to a plasma cutter made quick work of modifying the bullbar.
The whole kit and kabutle is now bolted up with the stock hooks (one from the front, and one from the rear of a 62), the stock brackets/braces and the stock bolts (2 through each hook, one down through the top). This leaves one hole in the top with no bolt in it. The bracket doesn't leave room for a standard bolt/washer combo, so I might see if I can grind down some washers to make it work, or just accept mounting the bullbar with only 10 bolts rather than 12.
Haven't had a chance to test the hooks yet, but will report back with the thumbs up, or gory horror story when I do.
Just in case anyone is interested in the tow bar set-up, it's a Reese unit I got at a clearance shop for cheap, brackets mounted to the front of the bullbar as close to the framerails as possible, with backing plates to sandwich the bullbar steel. Towed better than I could have hoped for, and aside from an icy pass in Montana, and bumper to bumper rush hour traffic through Calgary, the trip back was uneventful.
Looking down on it
Tweaked steel
Stock arrangement
