Hello to all,
I just purchased my first FJ60 after years of lust and infatuation with these wonderful machines. I have some history working on vintage volvos over the years but I'm no ace mechanic, just a normal guy trying hard to keep his cars on the road.
Prior to purchase, the PO walked me through a fuel pump/Fuel Cut Solenoid mod that he performed and mentioned that it occasionally fails, cutting all fuel the carb. He also mentioned that I should just "jiggle" the wires a bit to get it going again. This is obviously not going to work.
The previous owner installed a generic electric fuel pump (the old mechanical pump is still bolted into the block). In doing so, he also messed with the wiring to the Fuel Cut Solenoid. The FCS wiring harness has been disconnected. There is a positive wire from the the fuel pump lead, which appears to originate from the ignition. For a ground he ran a wire straight from the Negative terminal on the battery to the FCS wiring harness using the type of alligator clips a dentist might use on a bib. The female end of the wiring harness is dangling unused below the carb.
The whole setup seems questionable to me and the vehicle has already stranded me three times since I bought it last week. I've parked it in the meantime but I'm looking to fix it as soon as possible. The fuel cuts out when the car is idling for more than 5-10 minutes. It's not a problem at stoplights but is a problem when sitting in traffic. The motor dies, starter will crank but motor will not fire up. If I let it sit for 10 minutes or so, it comes back to life.
Does anyone know why the PO would have disconnected the FCS wiring harness and introduced this very questionable wiring scheme?
I want to test the female end of the FCS wiring harness with my trusty multi-meter. Does anyone know what values I should expect to find or what resource I could use to help find this information on my own?
My goal is to retain the electric fuel pump (if it ain't broke...) but return the FCS wiring to its original state. If there are underlying symptoms I should be aware of, I'd like to chase those down as well.
Thanks in advance to anyone who can help! If this problem has been covered elsewhere, let me know where to go. I searched for fuel cut solenoid and browsed all the threads but didn't see anything related to my wiring problem.
Brian
Brian
