Tire size w/o lift
crackdpot
2Cor4:7
Inter-Mountain Northwest
www.jonesdrafting.com
What're the biggest tires I can fit into my fender wells w/o lift, nip or tuck? I'm not rock crawler but want a little extra clearance without stability issues. Have original rims with Toyo M55's right now. It's cold & rainy out there right now and I'm not going out to check tire size. :steer:
i had bridgstone AT revos that were 31x10.5 they fit fine but i've heard of people going bigger with no lift.
As far as I know, you can go 33x10s and probably even 33x12s. Not sure about bigger than that.
don't forget tie rods...
I run 31.5 bfg on stock, saggy susp.
I do recommend you get fresh tie rods + relay rods, or at least in a year or two.
Last sun, my relay rod FELL APART, leaving me STRANDED, as the car COULD NO LONGER STEER. Friggin' scary..... Just glad no one was hurt.
I had 33X9.5s on a sagged out suspension with no problems.
MATT60------ What rims are those?
33 x 9.50 w/ stock sagging suspension.
attachment.php
I ran some BFG 31"x10" on my stock saggy suspension and I was able to do some decent 4 wheeling. I don't think that 33" would be too bad if you don't hit the trails.
Ran 33x10.5 BFG all terrains on stock wheels stock suspension. tires will be pinched a little but no big issues.
33x12.50-15's on 100% stock saggy suspension.
Nice Wheels!
Do you have a close up picture of your wheels? I've been looking for some similar to these. What kind are they? They're not the stock ones, are they?
