I'm currently replacing all my vac lines and preparing to reinstall my EGR cooler and pipes. So far, everything looks pretty normal on the drivers side, and I've already replaced 80% of the lines on that side. However, over on the passenger side, things are a little screwy. I have a full set of factory manuals, but I'm having a very hard time identifying this little bundle of joy:
I only noticed it because as you can see, the hose that goes to the bottom of the pic is not hooked to anything on that end. Also, I can't figure out which valve that is.
Here's another shot of how the hoses are hooked on to that valve:
Then, there's this one. I found it dangling down near the starter. It comes out of the corner of the firewall and goes to nothing:
THEN....to top it all off, it looks like one of the lines on my charcoal cannister has MELTED in half.....
All of this, and the truck runs reliably just fine. I did not do the desmog, and the only components I see that were removed from the EGR were the cooler and both pipes; everything else is still there.
Can anybody help?
--JP
Can anybody help?
--JP
