So, I posted this thread (https://forum.ih8mud.com/40-55-series-tech/288790-anyone-try-bad-idea.html) to see if it would work to use the tranny cooler from an '92 FJ80 (that I'm parting out - https://forum.ih8mud.com/parting-out/287091-92-fj80-so-cal-98%-all-part-intact.html) as a power steering cooler on my FJ40. Here it is still mounted (somewhat) on the 80:
I've seen a lot of guys use the smaller ones similar to this one sold by MAF for $27 - MAF Power Steering Oil Cooler Kit. The tranny cooler is, obviously, larger and can hold more fluid. The only questions would be: 1) if it would fit between the radiator and the mesh on the bib and 2) how to mount it.
At first, this looked like a pretty stout way to mount it - just drill 4 holes through the radiator support on the left side and then fab up mounts for the right side (BTW, I just ran the hose from one nipple to the other to keep the residual fluid from leaking all over the place):
Then, I tried to put the bib back in place and found that there wasn't enough room to clear the mesh
So, I walked away
and worked on another project for a while and then came back to this and figured this out:
The two tabs on the left side of the cooler (as mounted in the 80) just fit between the bottom of the radiator and the surround.
If you push down on it slightly (the metal is pretty thin) it kinda "snaps" snuggly into place as this lip fits under a little shelf on the radiator. It is perfectly spaced so the cooler and the radiator don't touch and "grind" on one another.
I centered it on the bib hinge (though it doesn't look like it here) and next I'll put a bracket across to attach the top of the cooler to the radiator support like this....
...to keep the bottom tabs from popping loose and to keep the top of the cooler from "chewing" on the radiator (it'll also provide some strength so the thin bottom piece of metal doesn't fatigue and break over time). I'll fab a little "L-bracket" on the left side (arrow) to bolt to the bracket too.
Once that's done, I'll run the lines. Hopefully, my pump rebuild woes will be resolved by then - https://forum.ih8mud.com/40-55-series-tech/287106-leaking-oem-40-series-ps-pump.html.
Putting the bib in place, it looks like it will be snug, but should work. I'm a little concerned about the support for the TOYOTA emblem on the grill mesh, but we'll see once everything is mounted up.......
Does anyone see anything I'm missing? Suggestions? Input is always welcome.
http://farm3.static.flickr.com/2166/3628812641_e58aac0f1b.jpg?v=0
So, I walked away
