I have been runnning Valvoline synthetic dot 3-4 brake fluid in my brake and clutch sytems for 6 years now. No complaints concerning the brake system, brake components have held quite well now for years. The clutch hydraulics on the other hand are a different bird. I have replaced both the master and slave twice now in the last six years. Beginning to think it is the syntho brake fluid. The clutch system accumulates an excess of black particles in the fluid much more so than the brake system. Question is, has anyone experienced a similiar problem? Should I switch back to the old stuff? What the heck is going on here? Along those lines.
Called up Apple & thought they may have inserted sleeves w/ loose tolerances around the pistons. They asked what fluid I was using & said my rubber components were not designed to use synthetics & were causing the rubber to deform. I disassembled the units & found that to be true. The slave seems fine, but I'll need to check that too
