Flywheel Question
Houston, TX
Can someone advise approximately how much I should expect to be quoted for resurfacing my flywhel? It's a 2F motor.
Thanks for the replies. I will keep the step/recess in mind.
My guys do it for $20. Make sure they know about the step that should be retained if they are not familiar with LC flywheels.
Retaining the step is largely a myth; your pressure plate is designed to accomodate the changing thickness of the clutch disk as it wears, and it is equally capable of compensating for the relatively small "step" between the friction surface and the shoulder.
I didn't want them to try to pull the pins out of mine so I had them surface the friction surface only and leave the shoulder alone. Absolutely no problems.
I just go over it with a sanding disc on an angle grinder until the surface is nice and evenly swirly ('cause that's what my mechanic did), and it's all good.
This kind of thought concerning a F engine/flywheel/three finger clutch assembly will net you less effective clamping force and accelerated clutch disc/pressure plate/flywheel wear since the disc will be allowed to slip easier.
The step on this style flywheel is opposite of the 2F/diaphragm clutch assembly.
I like the sanding disk idea, thanks.
Reading Steve's reply got me confused. My memory isn't what it used to be. The truck is a 1974 but 22 years ago the F engine threw a valve thru #1 piston so we got a 1976 donor truck and swapped motors. I know I put the three finger clutch and the 2/74 four speed back in, but now I can't recall which flywheel I used. Probably the one from the F engine. I'd put up a picture but it's still in the truck.
Have it turned, retain the step per factory specs, adjust your heights and youll be golden. Dont just resurface with a cookie wheel. If that hasnt been out in 22 years, its time to have it ground right down, there are bound to be hot spots and a few little cracks that the quick surface job wont get out.
Then you will have the three-finger flywheel/F engine flywheel, as the three-finger clutch pressure plate will not work on the 2F, or diaphragm clutch flywheel.
How big is the step on the F flywheel? I recall checking the specification for the clutch disk thickness and the variation in the disk thickness over life was so much larger than the size of the step as to make it negligible.
These are the step measurements on the F style flywheel and the 2F style flywheel...
F Flywheel uses the three-finger pressure plate. .630" step or 16.002mm
2f Flywheel uses the diaphragm style pressure plate. .020" step or .508mm
Again, from here <---- this is a link
Since the clutch discs are interchangeable between the two pressure plates, it only stands to reason that if you increase the step height, that you will lessen the clamping force.
I spent a couple weeks trying to figure out why my three-finger clutch was slipping after only a couple thousand miles of use, only to find that my step height was over 19mm. The step had not remained consistent during the years that it had been resurfaced. The machine shops had only cut the clutch disc wear surface.
Ding. :idea:
Differences in flywheels, treerootCO’s post from the best 2F thread:
I got out the scale for fun and was surprised that both the 3 speed and 4 speed pressure plates weighed in at 25lbs. The 4 speed flywheel is 34lbs and the 3 speed is 37lbs.
attachment.php
:beer:
$30 here on Saturday, cash, while you wait. At least that's how I got mine done!
Thanks again for the help. Thanks for the links also. I get it about the step now, good info to have when I take it in.
74 F with 4 speed
For a couple of months in 1974, F motors came with a 4 speed using the old 3 Finger type clutch. (Just some useless trivia)
Mine was one of them.
