Coolerman
SILVER Star
- Joined
- Jan 5, 2004
- Threads
- 143
- Messages
- 6,766
- Location
- Paint Lick, KY
- Website
- www.globalsoftware-inc.com
Well since I'm on a roll recently getting things done, I thought I would start a thread on my build.
Long story short: I have owned it for 8 years. Got the Cruiser from my younger brother who bought it from the original owner. Brother went through a divorce and about the only thing his X didn't take was the Cruiser. It was delivered to my house by a wrecker with no rear axle under it. I threw a tarp over it and forgot about it. After about a year I put the axle back under it cause he claimed he was coming to get it. Here it is after that... It then sat for another 3 years with the wife bitching about it the whole time. Details
As you can see this thing was a rust bucket!
Only in the last 4 years have I been working on it. I starting just trying to get it running and one thing led to another till last winter I decided that it was to be a frame off fix it up but NOT a restoration.
I've got hundreds of pics of the zig zag path I have taken in getting this thing to where it is now. For ANYONE contemplating restoring a Cruiser: Make the commitment EARLY on to do a frame off or not. I wasted so much time fixing things out of sequence....
Anyway I started by getting it running. This was easy, clean the points, put a battery in it, cut the fuel line and stick in in a can of gas, pour some gas down the carb and crank it. It started pretty easily.
This was a pic of the engine AFTER pressure washing it! Man it was nasty...
After getting it running I had to fix the fuel system. The gas tank had a few holes in it...
I completely cleaned the tank inside and out with muratic acid and used a fiber glass repair kit to 'fix' it. It has held gas for years! See here for a more complete description of the fuel system issues.
Over the next couple of years I worked on various things with no real plan in mind. I rebuilt the brakes in the rear, replaced the main brake lines which meant I had to learn how to do double flares, and worked on the electrical system. I knew deep inside that I was just wasting time. The body was simply rotted and no amount of fixing other things was going to change that.
So I bit the bullet and bought a small welder. I started practising on stuff then one day got to drinking with a friend and we tore into the rear sill job....
Funny how spirits lube the creative urge!
My rear bumper was toast from my brother trying to extract a fork lift that had tried to go off roading so I replaced it with a 74 bumper.
The more I got into the body the more I realized there was to do....
I ended up basically rebuilding the body piece by piece. Floors, cargo area, wheel wells, quarter panels, tool box.
It was about the time I finished this work that I realized I was so deep that a frame off needed to be done. Again with the wonder lube flowing I tore into stripping the tub.
The body was now strong enough to support itself with a bit of bracing so with my brother helping me we used a Hi-Lift and raised the body off the frame.
We got the body up on saw horses but my brother had to leave. So I had to figure out a way to get the body out of the way. This is what I came up with...
The body suspened from the garage ceiling with wire ropes and pulleys!
I can raise and lower it easily. This allows me to get the frame/engine out using a true hillbilly contraption.
I then pulled the engine/tranny/t-case out in one piece to see if my Harbor Freight picker would do it....
Next up was pulling the tranny/t-case off and putting the engine on a stand for de-greasing and painting. We will skip forward a bit here
The frame could now be sand blasted...
That's pretty much where I am right now. I do have the frame painted with Rust Bullet and will post pics of that later. Enjoy!
