Living in the Past
SILVER Star
I heard a long time ago about welding the one piece tranfer case input and PTO gears together on the four speeds. Has any body done this? Will the two gears fit thru the opening for the PTO box on the side of the tranfer case welded together? You would have to have it installed on the transmission's tail shaft to weld it straight. Since the fine spline on the four speed seems to wear I think welding the two together would slow this way down being that the PTO gear is spline all the way through and the input gear is only half splined. This would put the wear on a much larger area.
John
John
