Has anyone tried or used polypropylene sheet/plate for skid plates yet?
It has incredible impact strength and is very lubricious for sliding up and over obstacles. I've heard, not sure where, that they have been used and work really well. I'm just not sure how thick of a material one would use? 1/2", 3/4", 1" plate? I mean the stuff will take an unbelievable amount of punishment. It is sometimes referred to as a living hinge, because if you try to bend it in order to break, it will just bend, and will continue to bend back and forth and will almost never tear or break.
It's not too expensive compared to steel sliders. McMaster Carr has a 4' x 4' x 1" plate for $298.71 : McMaster-Carr You also might find it cheaper elsewhere too. McMaster is not the last word in low prices by no means, but they do have just about everything under the sun.
That I think would take care of the whole mid section. Or a 4' x 8' x 1" is $553.17 and you can chop that up to cover just about the entire under carriage.
Now, mind you, 1" may be overkill and you can maybe get by with just 1/2" or 3/4" plate.
And I think it might weigh a little less that steel. Not sure though. I'll have to calc that out when I get ready to bolt one on, if I can get a hold of a steel slider to measure and get a mass volume on it or if some one weighs one.
