I just got my new Hundy and I just could not handle the Gold Bling Package. I did a forum search and found some suggestions and I went with the Plasti Dip.
I decided to take the grill off (three screws...top of grill) and two clips on the bottom (left and right). Very simple.
Items needed:
-one can of black Plasti Dip
-rubbing alcohol (to clean the grill...drys very fast)
-paper towels
-painters tape (cover screw holes...really not necessary)
-several Coors Lights
-staging area with good lighting
I wiped down the grill for about 5-10 minutes and started spraying light coats about 20-30 minutes apart. I did 5 coats. The can says 3 should do it but the nooks and crannies of gold Bling were still showing. Also the thicker the Plasti Dip the easier to remove...if you don't like.
Some of my first coats were shot to close causing some discoloration. So I made sure my final coats were at a distance and consistent.
Next project: De Bling the rear letters. It needs a good cleaning since there is dirt and grim between all the emblems. I am going to leave them on (saw a tread on this). More pics to follow.
I watched a ton of videos. So I know if I change my mind I can just peal it off.
Items needed:
-paper towels
