I noticed a really strange CV boot issue on my 2000 TLC. On the front wheels, BOTH inside boots have a <edit - a bit of> > TON of grease coming onut, presumeably around the seal. The ones on the wheel side are clean and dry. The wired thing is, I looked under the boot, around the boot, pulled the wheel and looked on top of the boot - the boots are fine. No cracking at all. The clamp ring at the small end seems to be where the leak comes from (again, on both sides) but the clamp is nice and tight. I'm not relishing the idea of doing my own labor on these, but I had what may in fact be a Very Bad Idea I wanted to bounce off the board. What if I cut/removed the clamp, shot the thing full of moly, then clamped it back up with a hose clamp and snugged it down nice and tight? Would it have a prayer of holding? Also, has anyone else ever seen both inner ones leak with no visible wear, but the outer ones be perfectly fine?
EDITED - Pics from reply below showed me what "a TON OF GREASE" looks like. This ain't that. Mine would be "a bit" by comparison.
