I am looking to build some drawers in the next few weekends. I am also going to install a helton shower system. I have a few questions/ideas. Drawers will be similar to this:
https://forum.ih8mud.com/80-series-tech/136736-another-perspective-rear-storage.html
1. Does the inline pump that comes with the helton and other systems work well? I noticed most install a permanent shurflo, in these cases, are you ditching the small inline pump that comes with the kit. Snooks ROTW thread is very helpful, but I am still curious how the shurflo or similar pump is plumbed. Is it worth paying $55 for this showerhead/pump combo?
2. I am wanting to have water with just in case there is no water available. I thought about mounting one of these RV/marine water tanks in one of the drawers. There is a 21 gallon that would fit nicely in one drawer. I would not mount it permanently, so the drawer could be used for other purposes as well. See link below for the tanks I am considering. Any thoughts/comments on capacity are appreciated. The 21 gallon will fill an entire drawer, and a 16 gallon will leave about 12 inches in the front or rear, but will require the entire drawer system to be about 3 inches higher. This might make it too high to use as a sleeping surface. Comments???
West Marine: Polyethylene Water Tanks Product Display
3. I was going to use quick connects for water outlet, and make the pumping system capable of pulling water from the tank or another source. I dont want to run a water line from the engine compartment to the back inside of the truck. I would prefer to run it underneath and pop inside near the rear. Are there any penetrations in the rear quarter areas?
Seriously though, the onboard heated shower systems are not that popular around here.Portable lpg systems are available and some do use them but for the trips that I do we usually heat some water separately and shower/wash in a fold-up bucket, using a simple 12v shower pump, provided we have enough water. Another favorite is the solar showers ...
