I know there are at least a couple of MUDders that have installed body lifts. Maybe more.
It seems like when you get into the "true" 35" tires, like the Toyo OC MT (taller and wider than most), the best way to reduce rubbing might be via body lift.
<edit> What size lift are you running and why did you choose that height?
What are the pros and cons? Any other modifications to accommodate the lift like extending pedals, shift levers, etc?
DIY job? Was it a difficult install? If not, who did the work? Were the lift blocks custom made?
. 12mm is all I needed but you can lift as much as you want. Why would you want more BL than you actually need?
and starts to get into linkage issues. Remember there are a lot of connections between the body and frame besides the body mounts.
