Hey All.. I am looking for any suggestions on a reasonably priced and reliable tree trunk protector strap to use while winching. I have a 8274 on my 62 series... thanks !
We stock the new ARB Tree Trunk Protectors, zero stretch (for use with winch), heavy duty, color coded and available in two lengths, 10 ft and 16 ft. Pricing and additional specs here:
Cruiser Outfitters
Kurt: Any idea how much space the rolled up 16' ARB Tree Trunk strap takes up for storage? They certainly look like nice straps from the photos.
You could use a (strong enough) tow strap to use as a tree protector. Being a bit longer than the usual dedicated tree protector would make it also more useful for regular towing if you need an extension. Probably better that it not be stretchy (as in real tow strap not a recovery strap) but that is debatable I guess. If really too long in use you can just double it over (which could also help with the breaking point). Nice to have a piece of old carpet you can put between the strap and the trunk to reduce chafing.
Total shoot from the hip, 12" x 8" x 3"?
I am with e999,
i use a 3 inch tow strap for my tree duties. It works great, and i haven't torn a tree up yet. Although, most of the time i use it; its 15 feet; i wrap it 3 to 4 times and the use a 3/4 clevis shackle to attach it to the main line. However, the ARB straps, protectors and winch extenders look great! They are specifically designed for the job, and good for them, but i what i am doing is good for now.
Does anyone have an opinion on the 10 foot vs. 16 foot ARB straps ?
Which seems to work better in the real-world recovery situations... ?
So, strap selection is best determined by frequency of use. If you use them often, wear them out quickly, a strap with loop boots, etc, is a good investment, if it is seldom used, a strap with less features, cost, is likely better. In other words, they are a consumable item, not a lifetime investment.
