Your definitely not 21 and your management now, so....
What are those five longer bolt/studs from? Not to connect a driveshaft I think......Started to get the truck buttoned up, new stainless steel braided brake lines for the front:
I bled the brakes, filled the fluid, and took her out for a spin. So nice to have the 4.88 back, will roast the tires so easily if I power break it
The rear drums are scrapping the backing plates hard, so I will have to go through that as well.
The fix I thought I had for the transmission cooler lines didn't work, I believe the hard lines are starting to seep through the rusted bits. So thankful I have a spare parts bin in the garage... I pulled the hard lines off the brown truck and gave them a clean up. Thank you coal country dirt. That with years of oil preserved these 23 year old lines! I am going to give them a few coats before I pop them into the silver 4Runner:
Another thing I noticed is that I had a vibration in the front end when in 4WD, I have the front drive shaft out currently and I locked the truck into 4WD to get the diff to lock in and got no vibration which makes me think it may be the drive shaft so I pulled the one out of the brown truck and will install it later:
For now I am done for a bit and let my body recoup.
I see a mini truck case on the floor. Plans?
Annabelle coming along nicely Avi. Question- where did you get the washer kit? I deleted mine and never got around to fitting a new one. I was going to rig one out of pvc pipe.
Negative Andy- My truck has stuff jammed in that area already plus my ARB solenoid and the compressor- real estate is at a premium under the hood.
Haha we are doing the same project! I’m hoping to be done this week and be ready for the cmcc alternative weekend.
